wipers inop.
wipers inop.
82Scrambled
new jersey
1982 CJ-8 456 gears, ARB Air Lockers F&R, T-4 trans Dana 300
hi everyone
1st post of many.
just got this jeep and wanted to know the first few basic tests to check out whats wrong with the wipers. the washer motor works fine.
tks
It is a pretty good idea to check the voltage to the motor. Pull the plug in the wiring and check the voltage to ground on all the pins on the switch side, with the switch on and off.:cool:
Do you have intermittent wipers??:D
I wouldn't jumper the wires. There are a couple of ways to test this.
I may have misunderstood you earlier but did you disconnect the motor linkage and try to turn on the wipers? If the motor works like that then everything electrical is working.
Another test would be to check the voltage to the motor. That should be 12 volts when the wipers are turned on.
Do one or both of the above tests and let us know what happens.
