Wiring GM 2 wire alternator
Colo Dean
Greeley Co
74 CJ5 258 I-6, 4 spd T-18, Dana 20 T/C, Dana 30 Front, Dana 44 Rear 4.27:1, still learning everything about this one, 14 JK pretty much stock
I don't see a dunderhead around here. Not a bad idea on the potential drain actually being through the tester itself.
I was always nervous about screwing up the two wire set up on a Delco Alternator so when mine went bad it went into an alternator shop to get a single wire regulator set-up. Some say since the alt. needs to be run up to ~1100 rpm before it will start charging (once started it is always charging) that this is a bad system. But honestly, who doesn't feather the throttle at least a little bit on start up.
So I may have figured this out. There must be a capacitor in the alternator. After checking the battery voltage and again a couple hrs later it was the exact same voltage. Checking the fuse post it now showed 0 volts. Turn the key on and off and it goes back to the .6 volts but after a couple minutes its back to 0 volts. Tested this a few times and got the same results so I don't think I have to worry about this killing the battery.
One more issue hopefully solved.
Thanks for putting up with all my questions! I bet there will be more in the next week or so as we get this girl ready to run..
