Wiring GM 2 wire alternator
Colo Dean
- Greeley Co
- 74 CJ5 258 I-6, 4 spd T-18, Dana 20 T/C, Dana 30 Front, Dana 44 Rear 4.27:1, still learning everything about this one, 14 JK pretty much stock
So I have one other issue to sort out.....hopefully just one....
I installed a GM alternator and wired it as a 2 wire alternator basically the same as this drawing.
The only difference is my ignition wire from the switch goes to a fuse block and I connected one side of the light to the fuse panel instead of directly at the ignition switch.
In checking all of my wiring, I found with the ignition switch off, I am getting .6 volts instead of 0 volts at the post on my fuse panel. Not sure what I need to do to make sure I am not drawing the battery down.
Now to confuse you again, if I haven't already (sorry I can't always explain it as clearly as I would like)
While typing, this popped into my head. With this .6 volts on the line, would that be considered potential voltage in that the light is not on, since it doesn't have a ground but it registers when I give it a path to ground using the volt meter? Therefore not really draining the battery. My thought here is there is 12 volts at the ignition switch, but if its not on there is no drain, its just voltage waiting to be used.
Thoughts??
And if anyone is willing to talk to this dunder head, pm me your number and I may be able to explain it better.
Thanks.
Thoughts??
Thanks.
