YJ power brake swap. What air cleaner do I need?
Halfmoon
- GA
- 1984 CJ7 - 258 w/ mild cam and headers, T-18 trans,
Dana 300 t-case, stock axles & brakes,
4" Skyjacker lift w/ 35" BFG's
I'm planning to put power brakes from a '95 Wrangler on my CJ. I've looked at lots of threads about the swap. I can tell that my air cleaner clearance is going to be a problem as others have mentioned. But what air cleaner do I need to swap to? I'm ordering the booster and MC from a salvage yard and want to get another air cleaner with it. Will the master cylinder sit underneath the new air cleaner?
Do I need a YJ master cylinder too or will mine work?
Also, for those that have done the swap with the dual diaphragm booster, anyone know the distance from the firewall to the front of the new master cylinder?
Thanks!
Thanks!
junk yard brake parts, bad idea. The adapter, maybe. the booster and MC, no. that MC is about $30 rebuilt and the booster you need is the smallest diameter you can find, more than likely not something you will find in a grave yard.
