Yoke capes vs U-bolts
GatorBate
I need to get a new yoke for the rear diff. Is there any advantage to the U-bolt style clamp over the U-joint Cap or are they just two different ways to do the same thing.
I've only ran the straps and twice now I have broken the tabs that hold the u-joint caps in place and they have worked their way out. Yukon makes yokes for the AMC20 in both the u-bolt and the strap type. I've read that you can torque down the u-bolts until you deform the caps and as you mentioned, the threads can be messed up on the strap type. I guess I'm trying to find out if one is stronger than the other.![]()
