Build Thread 1959 CJ5 "One Piece at a Time..."
Get rr Done, hoping to see you all in Col.:chug:
I like the paint on the top you should paint the Jeep to match.
Alright now we have some pics. Time to gather up the Large popcorn and watch.:lpopcorn:
Those fenders have me interested. Im thinking they may be some old style Postal fenders. They have the lights on top of them like were on the top of Postals around here many years ago. Im going to lok into this and see what I can find. Id dump them for some classic Cj-5 fenders myself and it doesnt sound like youve fallen in love with them either.
Yeah I don't like them either - but we will go with functional for the trip...
I'm really hoping a lift will "force" us to at least "reshape" them:D....I told Curt to look at Dave's CJ and make the fenders look like that.....:drool:
Thanks - we will be there one way one another....
We found some axles from a '74 CJ5 Dana 44 rear Dana 30 front 11'' brakes with finned or fanned drums (cannot remember what they are called...:o) - these things were complete - they have Warn manual locking hubs both front and rear...(rear...????) - will investigate - maybe we lucked into a rear locker or some kind of traction aid....
Anyway - we used our '91 Ranger to go get these and when we got home noticed a very bad squeaking noise coming from the suspension. The frost heave in the roads here is about the worst I have even seen.
So now we have something else to fix...:(
Sounds like you have the Warn free floater kit in the rear Dana 44 . Good for flat towing but no locker advantage. ;) Nice that you could add your sewing tech into a build thread. :chug:
Sounds like you have the Warn free floater kit in the rear dana 44. Good for flat towing but no locker advantage. ;) Nice that you could add your sewing tech into a build thread. :chug:
We pulled the cover off the Dana 44 and there was no locker...:( - There are little allen screws in the rear wheel lockers - you have to unscrew these a bit - and - there you go - almost like taking the rear driveshaft off. When these are unlocked - the wheels turn, but not the differential. Now I know what it's called...:D
My next question is:
Can I still install a rear locker with these rear locking hubs?
We pulled the cover off the dana 44 and there was no locker...:( - There are little allen screws in the rear wheel lockers - you have to unscrew these a bit - and - there you go - almost like taking the rear driveshaft off. When these are unlocked - the wheels turn, but not the differential. Now I know what it's called...:D
Yes. Id talk with someone here that has the full floater kit. I believe the hubs will be your axles weak point then. Pretty sure Sasquatch was someone who had one. I never have.
I have the old style Detroit Locker, which is probably pretty had on those hubs. I can say just to go easy on tightning that rear set screw, since it can push thru, and I have replaced them with stainless for rust issues. A little dab of locktite would be good also. I believe those hubs are the type used in the Dana 60 axle and have never had a strength issue even with a 103 to 1 low gear. I once hardness tested the axles and got a 55 on a Rockwell C scale which is quite hard. I did hear that the older style kits only used the original 4 bolt setup on the rear brake backing plates and mine is converted to a 5 bolt, if that even makes a difference.
