Build Thread 1959 CJ5 "One Piece at a Time..."
Good progress!
Good progress!
Ah, but will it be enough! More pictures coming soon, but we have hit a wall with the clutch set up!
No worries. You'll make this work. Great, great progress. Extremely happy for you!
The T-14 comes from the factory with a 10 spline output shaft
The T-86 , T-90 , T-15 , T-150 , CJ T-18 , has a 6 spline output shaft.
What is the casting # on the tranny?
Part # 3.15 kit?
The T14 comes from the factory with a 10 spline output shaft
The T86, T90, T-15, T150, CJ T-18, has a 6 spline output shaft.
Part # 3.15 kit?
Got the 2 of them mixed up. Wrote this late last night, and didn't remember which one was which. Bottom line, the Tera Low gear would not fit the T-14 . Already sent it back and am heading in a different direction.
Not a problem
I'm not sure why the rep told you the kit only fits 4 speeds, of the 5 I listed above 4 were 3 speeds that should work with the 3.15 kit.
Well there's nothing wrong with that backup plan. Don't forget that a stock CJ will do everything that you need it to do in Colorado so don't burn your RJ money on the 7 beyond getting it reliable etc. Your call.
I hear you, we pretty much have RJ's finances set aside already. About the only really costly thing is going to be the drive shafts. We are going at break neck speed to get something ready, and in spite of all the problems with our most recent purchase, the 7 is probably going to be a quicker build. No way we want to miss the Ouray trip!
