1966 cj5 Broken Clutch Rod? New Jeep, New Member
elijah
Union Mills, NC
1966 CJ5 pretty dead stock. 4cylinder.
2010 Scion xb. ;)
I would suggest that you go ahead and order it. Have a look underneath the vehicle and see what all is involved to replace it and become familiar with how the linkage works. Look for related clutch linkage parts for wear that should also be replaced at this time. Check the pedal freeplay and see if it needs adjustment after the system is repaired.
fix it forever.
trip to the hardware store.
buy a couple of threaded clevis forks and clevis pins.
measure and cut your old rod.
thread both ends of the rod.
install jam nuts and threaded clevis ends.
re-install, adjust as needed, never worry about that rod again.
the design is such that all the strain is on the 90* bends.
with clevis ends, it's now just a straight pull, no 90* bend to break.
simple.
Elijah,
I just finished a rebuild on a 59 CJ5 and parts I couldn’t find anywhere else I found at Jungle Jim’s Willys Jeep Parts (HOMEPAGE).
By the way, what part of Weastern NC? My wife is from Shelton Laurel.
Hey all,
Thanks so much for the tips! I think I will try to make the part myself out of some steel or brass rod I have around. If it doesn't work I can always order the 7$ part. :)
We live in Union Mills, NC. It's in Rutherford County...We just moved here from Asheville. I'm not sure where Shelton Laurel is.
Thanks!
-elijah
