1974 CJ5 Alternator Wiring
Sic
South
1974 CJ5, 4.2L straight 6, 3 speed manual transmission
Interesting, the Haynes manual is quite complete with the setup of the Motorola alternator. Those crimp terminals do not hold up very well, unless soldered and sealed.
Torxhead, thanks for the response.
I did not want to make the connections permanent until it was connected correctly, thanks for the tip.
Not sure what alternator you have, many came with a 37Amp. A AMC 258 i6 / 4.2l with A/C car came with a 68A. Uses the same regulator.
:D
JR
73CJ
Thanks for the info
It helped I got it worked out now
