1974 CJ5 rear axle question
1974cj5
Omaha, NE
1974 CJ5, 258 inline 6, T18 4 speed
Bad seal.
I will go out on a limb when I say this but no Jeep rear axles ever lubed the wheel bearings with gear oil. always grease, the theory of it is good until the outer seal goes and oils your brakes. Some/most of the rear axles will have the seal just outside the differential bearings and no oil in the tube.
I will add that my early Dana 44 tapered shaft has the inner and outer seals and a grease fitting threaded in the tube right at the bearing area.
You have a Dana 44 in the rear.
The factory manual says to pack the seal and bearing with grease.
From the pictures it looks like you are due for new grease.
You should probably replace all seals and bearings.
Thanks for all the great input guys.
My rear end has the inner seals just about 2 inches inside of the outer axle bearing. should I pack the entire cavity with grease when I reassemble? Would it be a good idea to add a grease zerk to the cavity area?
Thanks again
The important part is to properly pack the bearing, grease around the outside of the bearing or filling the cavity will do nothing to lubricate them.
I say no to adding a zirc fitting.
