1977 CJ& Wheel Lug & Hub Question
DanPan
SW Michigan
Hi All
I just acquired a 77 CJ7 . I purchased some tires and wheels with 5 x 5.5 bolt pattern. When I got the tires/wheels home I was dissapointed to find that although the lug pattern fit, the center hole on the wheel was too small. Question, is the "wagon wheel" type rim that's on the vehicle now the only kind of rim I can use with the large 4.5" center hole? Thanks!
most any aftermarket wheel with the correct pattern will fit over that hub. You bought some older style stock wheels (apparently) that still have the smaller holes.
A few guys have taken those small holed wheels to a machine shop and had the centers opened up enough to use them on the CJ hubs.
Those wheels were made for a 2wd Ford. :)
After taking all of that info into account...is there any reason to stay away from alu.? or would it be preferred.
I'm looking at a set of steel, gun metal colored rims 6 lug, but is there an advantage/disadvantage to alu. esp being on rough terrian.
thoughts?:confused:
