1979 AMC 304 Rough idle.
jafo
Old Time Jeeper
Ok. Intake gaskets tomorrow! Yepee! Oil pan gaskets too if time allows.
Best CK the new carb gaskets for leaks.
with HH here! When it cuts out-Is it sudden or what??Just for reference I live at ~2800 elevation and my vacuum is just like yours ~18-19. Your engine cutting out doesn't sound like a vacuum problem to me. I am thinking you've got that beast about whipped. Just shutting down sounds like jetting or electrical. I can't remember, how is your fuel pump? You could be sucking it dry. Have you checked your float?
Without question you are getting there.
With all your readings being very close your compression looks fine to me.
Where is the stock filter usually located? I would think along the frame some where? This bigger filter has two ports on one end and one port on the other.
Hmmmmmm .... On my CJ the thick gasket goes under the carb. and the thin one goes on the manifold. But I don't have the thick aluminum spacer, mine looks like that one but it's a phenolic (looks like old fashioned Bakelite to me) spacer that is supposed to be there for heat control. Sorry, I'd like to be able to help you more. ........ did you replace your power valve? Also, there are some parts in that kit that don't belong on your carb. I know this because a friend rebuilt his, had trouble with it and brought it to a rebuilder. He found incorrect parts in the carb. The odd part is that nothing other than experience will tell you you've used the wrong combination of parts. A simple change of a rubber gasket and the carb ran like it was new. aaannnnndddd that's all I can do for you, I believe it's a carburation problem. The jeep is just running out of gas.
Mine is to the left of the carb above the intake.
I think this pic is the new coil location. Does anyone see anything bad about this location?
Get rid of the 'horseshoe' connector on the coil. Well known problem area for intermittent miss due to bad contacts. Sound similar to what you are dealing with now??.........
Go to NAPA and get a new coil with screw down contacts.
Drivers side where the fuel line comes up over the intake? If so, the one that's on mine is not the correct filter. I think I'll just get a regular inline filter and put that in. Maybe get a fuel pump also. I have no idea how old these parts are and I'd rather replace them now than take a.chance.on them failing at a bad time. At least I'll know it should be good to go for some time.
Just a FYI-Old dried out gasoline, looks very oily also.
FWIW: I have had very good luck with Aviation Form-A-Gasket non-hardening liquid, for intake manifold sealing as well as carb base. It's also excellent for sealing all bolt threads the protrude into water jackets like head bolts and such.
The NAPA PN is 765-1210.
Yes and the return line is there also. After hearing how much the intake weighs if I have to pull mine I will be looking for a aluminum one. But I have yet to even get it running.
