Misc. AMC 20
Misc. AMC 20
shustring
Billings
1974 CJ 5 soon to be 360ci, 4 spd. , 1979 FSJ Cherokee, 2021 Rubicon, 1983 CJ7 258 Auto.
So the hub on my AMC20 drivers side spun I put a new axle and hub in per the instructions. I tightened the hub down to get the 1 5/16" from the end of the shaft to set the splines and torqued the nut to 250 FT LBS. now with the wheel and tire on it sticks out about an inch and a half more than the passenger side. Has anyone else run into this?
Did you buy the correct part? There was both a narrow trac and wide trac AMC20 .
Did you buy the correct part? There was both a narrow trac and wide trac AMC 20.
The web site at Extreme Terrain only showed one. I looked at both the old and new axles and they looked the same.
What year is your AMC20 ?
Wrong offset wheel
  100.0%
