1979 AMC 304 Rough idle.
jafo
Old Time Jeeper
Run your main battery GND to the top bolt of the starter! Have secondary GND's go to the frame and firewall. You want the same wire gauge as the battery cable is.
Don't forget the dash GND. You can use 10-12 ga. stranded there.
I also recommend secondary body to frame GNDs towards the back of the body on each side.
Do this before any other mods.
I'm on it. I was looking at the alternator and found the main battery wire loose. I mean LOOSE. I've checked about every nut and bolt on this thing and am still finding stuff loose.
