Build Thread 1979 CJ5 Frame off Restore
mark23487
Windsor, VA
1979 CJ5 304
Don't give up:chug:
The frame is in fair shape except in the rear around the spring hangers. 66jao6lcq-k0XQabQUS1ri2QwAp3gd_P4ko=w368-h207-p-no.webp
The gas tank was very easy to get out
This is looking out toward the driver side across the rear cross frame.
:chug::chug: looks like the work on the tub is gonna be fun :eek:
Gotta get this thing down to the frame!
There, one step closer! I hope I have it in me to see this all the way through!:confused:
Nice to see another Jeep on the road to recovery!!
Best of luck in the process
Thanks for the good wishes!!! This is a lot more fun than I thought it would be!!!
Oh ...... You can bet I'm well armed!!! DVC -- Diligentia, Vis, Celeritas
It is fun to tear them apart. The challenge comes trying to get all the little things back together right side up. :D
Good luck with it.
Re: 1979 CJ5 Frame is bare!
All the way down to the frame! :D Now comes the fun part! :chug:
A nice cllean frame to work with! The front three fourths of the frame is in excellent shape.
Definitely worth repairing the back end! :)
Rear driver's side from the top. I'll sand blast this and cut out
the worst metal, then weld in some new. My hopes are that I
can weld,grind, then weld and grind some more until it's pretty.
Front underside.
Rear driver's side from the bottom.
Rear passenger side from the top.
My helper and confidant!
:dbanana:
Now that it's down to the frame the cutting, grinding and welding begins!:D
https://lh5.googleusercontent.com/-6yuB6snaimY/UrHKjbQ_uZI/AAAAAAAAE-o/HcY7sLKHSLk/w957-h539-
no/IMG_20131216_210053975.jpg
The inspector says Okay!
I have bookmarked your g+ photos page for reference. I am rebuilding a 76 CJ5 which I purchased during mid rebuild so I don't have the reference pics. Your breakdown is a goldmine for me. I am currently working on my tub and am about to begin going back together with everything. Thanks for the pics. Good luck with the rebuild !:chug:
