Brakes 1979 CJ5 Hub Assembly - Removal
Kpasa123
Texas, USA
‘74 CJ 258
:welcome: @Kpasa123
What is that front dif out of? Can you take some shots of the dif cover and knuckles? 75 CJs did not have disc brakes.
Ah, :dung: ! I miss read, it's a 79! :doh:
Still would like the requested pictures...
I don’t see anything like that on this assembly. I’ve looked everywhere for signs of a nut or attachment. There was a split ring on the very front of the shaft that I removed. Still no movement. I can’t pry off the gear by any means.
The center of the spindle has threads but nothing was attached to it. Should I try a gear puller with a bolt threaded into the center?
Any idea what type of axle/hub this is? I can’t find nada. It must not be a typical CJ5 front end. I’m about to go nuts on this thing. New rotors are laughing at me!
Q-bo! Did you figure it out…
Not quite yet. Not any configuration I can find yet. Is it a different locking hub or is it the whole front end? The splines at the front of the gear seem like they want to come off with a puller. I’m on the homestretch with this project and really hit a brick wall here. I’m hoping someone can identify this setup and the ensuing eureka moment.
Looks like you’ve already removed the circlip that holds the manual locking mechanism (hub) to the stub shaft end. That’s what holds it in place if memory serves me correctly. Then it should slide right out. I think it is seized to the stub shaft. Try a large pulley puller or give it some controlled whacks. Once the manual locking hub comes out, then remove the large jam nuts and the hub/rotor assembly comes right out.
Solution
Thanks Patrick!! Now I know where to apply my force. This helps immensely.
Is this a standard Jeep front end? Or did this come from a donor? Might help me out along the way with future developments with this bastard of a jeep.
One more thing…could I use any type of gear puller to separate it? The rotor was fused to the hub plate. Not sure I’ve got a sledge big enough…hahaha
To me it looks like a regular CJ axle.
Be careful where you apply force. Some giant Channellocks and a brass hammer might be useful.
Do not attempt to separate the rotors from the hubs until you remove the assembly as a unit. Drive the studs out and then the rotors can be separated from the hub.
$20.00
  10.0%
