Brakes 1979 CJ5 Hub Assembly - Removal
Kpasa123
Texas, USA
‘74 CJ 258
I need some help here. I’ve looked everywhere for a diagram of this front hub assembly. I cannot for the life of me figure out how to get it off to replace the rotors. I’m unsure of the brand of hub. It does have 6-bolt pattern. Doesn’t look like a Warn.
All the photos and videos I have looked up have a spindle nut. There is NO nut. I’m at a loss.
Any help is much obliged!!
Honestly, I have no idea what the diff came out of. I thought it was the stock diff. It’s been in a barn for 20 years and I scooped it up and have been fixing one thing at a time. Everything else on it has checked out so far. The first hurdle I’ve come to thus far.
Looks like a factory Dana 30 with those crazy pinned nuts.. Did you try unscrewing after pulling the pin out some then tapping in the slot in the CCW direction?
I don’t see anything like that on this assembly. I’ve looked everywhere for signs of a nut or attachment. There was a split ring on the very front of the shaft that I removed. Still no movement. I can’t pry off the gear by any means.
The center of the spindle has threads but nothing was attached to it. Should I try a gear puller with a bolt threaded into the center?
Q-bo! Did you figure it out…
Not quite yet. Not any configuration I can find yet. Is it a different locking hub or is it the whole front end? The splines at the front of the gear seem like they want to come off with a puller. I’m on the homestretch with this project and really hit a brick wall here. I’m hoping someone can identify this setup and the ensuing eureka moment.
Looks like you’ve already removed the circlip that holds the manual locking mechanism (hub) to the stub shaft end. That’s what holds it in place if memory serves me correctly. Then it should slide right out. I think it is seized to the stub shaft. Try a large pulley puller or give it some controlled whacks. Once the manual locking hub comes out, then remove the large jam nuts and the hub/rotor assembly comes right out.
This is what you are dealing with and should slide right out.
Solution
Thanks Patrick!! Now I know where to apply my force. This helps immensely.
Is this a standard Jeep front end? Or did this come from a donor? Might help me out along the way with future developments with this bastard of a jeep.
To me it looks like a regular CJ axle.
Be careful where you apply force. Some giant Channellocks and a brass hammer might be useful.
Do not attempt to separate the rotors from the hubs until you remove the assembly as a unit. Drive the studs out and then the rotors can be separated from the hub.
$210.00
  100.0%
