Build Thread 1979 CJ7 Rapid restore - 1 Year build from tired and rusty to all go and some show..
nice looking trail tires, I run only 15's except on wife's JKU
I will be hitting up the cutting supply isle to grab a few of those disks next time I am in town! Its like trying to grind through Velvetta Cheeze...
I had great success cutting aluminum on a table saw and coarse carbide teeth. You must wear proper PPE.
Bet the passenger can’t hear any road noise with that setup
Guess those will blow you out with the top on. Top off, mine do fine on the highway. Top on, almost too much - almost. But they do hide the rattles for sure.:punk:
I almost went with the Rockford 6.5" but they were pricey from what I recall. What pods do you have? I'll be able to move mine back once I deal with the rollcage and have some extra bars to mount to, you kind of loose the stero effect with one speaker this close!!
Well.. finally got out of the garage today. Figured I would bounce around my back field first and check my steering work before anything further...
Back in the garage.. coolant leak coming from the passenger side head, looks like it's bubbling through the head bolt 😔 have to triple check all other possible source but sure looks like I'm pulling this motor... No fluid crossover so that's good but a good amount coming out.. looks like not at idle but give it a bit of load and that's when things appear to get wet. Have to pull that plug out also once it cools down and check that cylinder..
Major drag.. I am just at the 1000mile break in point and haven't even had a chance for a full pedal pull 😕
I almost went with the Rockford 6.5" but they were pricey from what I recall. What pods do you have? I'll be able to move mine back once I deal with the roll cage and have some extra bars to mount to, you kind of loose the stereo effect with one speaker this close!!
Mine are Clarion CM7123T units. I have a YJ sport bar that gives me the option to mount a bit back and at an angle. Here's a write-up: Stereo Setup
Grrrrrr. Enough to piss you off for sure.
$45.00
  22.5%
