Build Thread 1979 CJ7 Rapid restore - 1 Year build from tired and rusty to all go and some show..
Like this? Having the tool is easy, working it is hard...
I bet you can pick up one for a song now. That is a 602, all manual but accurate scales added. For a few $ more you can get a 605 fully servoed
a slippery slope>> more machinery = bigger shop = larger electrical bills = smaller bank account = angry wife = now sleeping in larger shop
I agree. But if you don’t remove the cover you really never remove all and if there is a problem you maybe never catch it before being catastrophic. Just my 2 cents. I’ve never had any problem with my diffs.
A lot depends on your usage I would say. where I like having the drain is when frequenting water.. It makes fluid changes a whole lot faster just to pop the plug and make sure no water has made it in. I like the double top plugs also, slightly less mess when I filled it!
Great point
That’s a good, stout cover.
I’ve been looking too for one with a drain.
A lot out there with skulls and stuff instead. WTF?
There seems to be a bit of junk out there. This one from spicer seems like one of the better values, I think it was just under $100US from Summit racing, they had a bunch in stock a few weeks ago. I looked at others alot more expensive but fail to see what you get for the $$.. aside from a skull emblem 😄
Your rockers are poly-lok rollers. There is no torque spec.
If you have a hydraulic lifter cam you put each cylinder on top dead center and adjust to zero lash then one half to three quarters turn more for correct preload then lock the poly center screw.
These heads do not have rocker studs installed and have no adjustment capability as-is, they are bolt down and go...
Did they have to work both heads ? I forgot you had the V8.
just the one - passenger side. at least only the battery & tray to move out of the way which is easier than the brake booster on the drivers side. You could do it without removing anything but it would be awkward I suspect getting at those back bolts squarely..
Wow, I have never seen that type of roller rocker. Do you have a link or part number? The 1.6 ratio EPWI roller rockers I found are all adjustable poly-lok type.
Edit: I went back and saw this post where you linked to the non adjustable rockers
Wow, I have never seen that type of roller rocker. Do you have a link? The EPWI roller rockers I found are all poly-lok type.
I had to go back out to the garage after your reply to make sure I wasn't losing my mind 😂. There is single thin baseplate with a equally as thin individual shim on each side. There is no way to adjust these that I can see. I recall this kind of setup I used on a ford 351C 30 some years ago. Too much shim left valves open, too little meant late opens and rattling pushrods lol. I'll grab some good pictures and post them tomorrow.
Fired up the engine over the weekend and well @%$%#@ and.. leaking head gasket :( coming out the last water channel I suspect, no fluid crossover and its running nice but off she comes again.. luckily I bought an entire gasket set about a year ago so I have 2 more chances to get it right..
This was my first time using copper spray, maybe I was a little light on the coat?
$45.00
  22.5%
