1980 CJ5 Clutch
OldJeep
- Morris
- 1980, CJ5, Manual 3 speed not sure, transfer case not sure, diffs not sure,
Hi to everyone. I'm new to Jeep-CJ forum. I bought a 1980 CJ5 AMC 258 i6 / 4.2l three speed. I need to replace the clutch, but the problem I'm having is the motor has been changed and I'm not sure what Transmission it is. The stamping on the block is 304C27 and the only number I can find on the Transfer Case is 2603983 and the tag on the transfer case, there are two numbers (309001-14) (5359121) The input shaft on the trans is 10 spline and Dia. 1.058 and everything I'm finding for a clutch disk are showing 10 spline and Dia. 1.125 I would like to replace pressure plate, disk, release bearing and flywheel. If anyone knows. Please let me know. Thank you
