Build Thread 1981 CJ7 Trail Rig Build
I’m liking the color. Looks a little lighter than Forest Service Green.
Thanks! It's a Fiat color that has been around since like the 50's. PPG Verde Chiaro. Same color as the little Fiats that you see running around. I also thought that it had a little bit of a USFS vibe!
Yeah that’s looking really nice. :chug:
Definitely gonna be a cool rig, kinda making me wanna strip down all the paint and vinyl thats on my hood and get a new set of stickers
This Motobilt rear bumper came with some 4" boomerang shackles. They angle opposite of normal, to clear the front bumper. I've still been waffling on how exactly I'm going to outboard the front springs. I bought some frame outriggers from Barnes. Also not sure how far I'm going to try to stretch the front axle out. I bought the Rubicon Express 1444 SOA springs. Contemplating putting the shackles up front, and kind of mirroring the rear bumper, with some 5" "boomerang" shackles that I ordered. I'd be happier with driveline movement putting the shackles up front, though, the springs are more susceptible to damage with the shackles up front, versus the spring hanger being up front. I'll probably mock it up both ways and decide how to proceed.
Those welds look beautiful. So does the rest of the work so far.
Hey, thanks! It's been a few years since I've really welded much, so I'm still knocking the cobwebs off!
What welder do you have? You are making some nice welds
It's the Lincoln 215 MPi.
https://www.lincolnelectric.com/en/Products/k4876-1
I've been VERY happy with it! When I was shopping for a welder, I was planning on buying a Miller 212. While shopping, I bought an old '70's jet boat, that had a cracked block, that I intended to flip. I was going to do an engine swap. While researching welders, I had read about how these multi-process welders had greatly improved in quality. So, this welder will MIG, TIG, and stick weld! And, I even have an aluminum spool gun for it.
So, I had landed on this machine. The tipping point was that it would stick weld. So, I bought it and some high nickle content rod, pre-heated and welded the cracked Oldsmobile block, then post heated with a torch and packed with sand, in an effort to slow the cooling process. I ran that boat really hard on multiple trips. I sold it with that engine, and last I heard that engine was still running strong, after two years.
It's a great machine! No more reading a matrix of MIG gas, wire diameter and material thickness. When you fire it up, you run through some questions on the screen, and it sets everything for you. You can, of course modify the settings for various conditions. But, overall I could not be happier with this machine! I highly reccomend it to anyone looking for a good welder, that will do a lot of different kinds of welding. It will also run on 220V OR 120V!
I run this machine almost exclusively with mix gas (75%/25%), 0.030" MIG wire, and on 220V.
Anyway, I digress. Sorry for the Lincoln sales pitch! I actually used to prefer Miller welders, but apparently am a convert.
These newer inverter style machines take welding to a whole new level. I recently acquired the the Miller Multimatic. I use 100% CO2 for mig and Argon for tig with exceptional success.
Not to mention the stick welding. It sounds very different, and the beads mimic those of tig welding.
