Build Thread 1983 CJ7 FRANKEN-J build
also bought all new leaf spring shackles and bushings
I do not have a write-up or other pics, sorry. My CJ had the AMC 258 i6 / 4.2l 6-cyl in it before the SBC swap. Not sure of mounts on a YJ frame vs the CJ frame. I simply used some 1/4" steel plate about 7" by 5" rectangle shaped. I drilled holes about 1.5" in from one end to line up with the mounting holes in the frame welded mounts. I then drilled a series of holes about an inch apart toward the other end of the plate that would line up with the SBC engine mounts. So this allowed me to mount the plate to the frame mounts, and then select the best position to mount the engine (using the standard SBC mounts) an adjust forward or back an inch at a time, getting the best position for distributor clearance at the rear and also fan clearance at the front.
So bolt your engine mounts to the block, bolt the rectangular pieces to the welded frame mounts, then drop the motor in and determine your best alignment, and then run bolts through the rectangular mounts into the engine mounts on the block. Easy-peasy and just two pieces of scrap cut to size and some holes drilled.
If I understand this right, you use both the sbc engine mount for the engine and the sbc lower frame mount and your new plate goes between the lower frame mount and the Jeep's welded bracket using the plates holes for alignment?
New leaf spring u-bolts front and rear arrived today!!!! Getting close to starting on the frame, looks like I need to order new rear upper shock mounts though, 1 broken bolt plus they area right where I have to do a minor patch both sides.
And, 5 bolts away from pulling the sbc 350 out of the Silverado for Franky, rough going though, hoping to have it on an engine stand by noon tomorrow.
I'll probably take some pics before installing, to show you, might make it easier for me to understand what you did, I was even considering just making some 1/4 in wedges and use the motor mount from the chevy, cutting off the oem frame mounts
Yes, you do have a long drive line to deal with. I tried a single electric fan on mine initially and still had overheating issues. The Contour dual electric was a perfect solution. Slim, dual fans and dual speeds, fits the SBC version of the CJ radiator perfectly, and readily available brand new on Amazon for cheap.
I take it moving it that far forward didn't give you any oil pan to axle clearance issues.
As long as you have a "truck style" oil pan on that SBC, no issues. The oil pan has the sump at the rear. Many of the "car versions" have the sump at the front or even a full length sump. These will hit the front axle. I also have a 4" lift. So more clearance from that as well.
cool, I'm using a truck 350, and will have approx 3" body lift and a couple suspension. Will raise motor accordingling, making sure whatever mounts I make I can add spacers to lift.
Motor pulled from donor..wahoo, actually went smoother than anticipated. sold some parts from donor and scrapped the rest, got half my money back from initial purchase.
Picked up a new-ish HEI distributor, billet style valve covers, ubolts for suspension came in.
That’s a hell of a long driveline. Find you an AX15 tranny and buy back your Dana three hundred. If using driver’s side front axle, they’ve come up with some good flip kits.
um...no, lol, probably do a SYE once I realize the final length of the rear drive shaft.
I'm betting the Chevy 5 spd from a 91 Silverado is probably a lot stronger than an AX15, I could be wrong, but the combination I'm using was made for and can withstand a stock sbc350, I know others have done mixed combo's with great success, I'm betting my axles will be the first to suffer if I beat on it.
Sure.
Correction, must have been tired when I typed my drivetrain combo, I have a NV3500 Chevy 5 speed and NP241c 32 spline all behind an 88 350 Vortec
You are still tired.
