Build Thread 1983 Jeep CJ7 RHD British Export Tub Swap
If I go with the original paint color... Sherwood Green Metallic, I would want someone to lay down the paint as it seems to be one of those things that I am just not capable of.
I will do all the bodywork and get it 90% of the way there... and there is a ton to do.
If I paint it myself, I would probably roll it on as I have done in the past or maybe try to step up to painting with a gun, and use a single stage paint... not sure yet.
I want to run the original Renegade graphics, but am not sure what else it wold look good on. I was thinking bright colors, yellow, orange, red would look good with them, or black... but want to stay true to the original, but I am not totally in love with the original color... I know, I have said a lot of words and said little ;)
cb
Cert and Pete, I plan to spray my Jeep when I get to that stage. I tested myself on my trailer that I restored for my Jeep. I used a regular car enamel the first try, but really didn't like the way it sprayed or looked. :( I think it was DuPont's DIY Auto Enamel. Anyway, I switched to a Ceramic urethane by Eastwood for the second go. I really like the easy of spraying, dry time, everything. :D So this will be what I use on the Jeep. I didn't do a coat of clear on the trailer, but will most likely do that on the jeep. What do you think?;) Rod
Tools were a HVLP spray gun from HF, and my 7.5 hp compressor. See more here: http://www.jeep-cj.com/forums/f98/79-cj7-frame-off-resto-1st-time-project-20075/
How about British Racing Green for a UK themed Jeep CJ7 RHD?
Also, I got the bottom of the tub blasted in the snow so I can start the body work on the underside
and the firewall
OLD ONE with plate removed
and new one, have to make it fit
The new firewall was also blasted to make way for surgery on it as well.
cb
I think if I was going to go green it would be the Sherwood Green Metallic. Having to pay someone to spray it sounds a bit costly though. Plus I always here horror stories about waiting for stuff to come back from paint. Whats the roll on system you used for the other Cjs like? Thats something Ive never tried.
That is the original color and it will cost a lot to spray it AND the paint is expensive... so, as I said, I want an affordable solution and I want to enjoy it this summer, so this is it for this year... once it is all back together and all the bolts have anti-seize on them, someone else can take it apart and spray it!!!
I did all the hard stuff!
cb
Not too much to report... working on the rear of the Jeep getting it all bolted up in the right places to make sure the new stuff all plays nice together... clecos are helping the process.
I don't have the pictures posted up on my website at the moment, so I will fill this back in when I get it done later this week.
cb
Wow! That is really nice work! :notworthy: Where do you buy your body parts? They look like really good quality. I should be starting my body repairs soon. Rod
Most of the stuff came from classic enterprises... the hard to find parts... pricey, but very nice quality
Jeep Front Body Supports (Toeboard Support) 76-95
as for the rear fuel filler panel, I think that came from Quadratec and was Crown or something... decent quality, no complaints.
I bought the clecos as well and they worked out well.
Only thing that didn't work out well was the spot welds and drilling them out... I suck at it... and I don't have proper spot weld drilling tools.
I got it all ground down and weld through primered up last night and got it all back together... welding it up next!
cb
Got the rear all welded up and the mid brace and front bracket along with some floor repair under them... finishing the floors will wait till I flip her over.
cb
Working on the tailgate section with all the parts and bits and getting back to welding on the front of the firewall... more pics later... just trying to catch up with what has been done.
cb
Plate needs some work, but it is coming together
due to this being rotted
and finally, how it sits, the rollbar fits, but the feet need some work
cb
More cutting, fitting, drilling, smoothing, etc.
I got to work on the opposite site a little last night but no pics yet.
cb
You probably have more hours in the firewall of that Cj than I have into the whole body of mine , and it shows. :D Nice work as always. Get any takers off the Craigslist ads yet?
Lots of emails, everyone wants to see it finished and then pay less... I guess that is just the way it goes.
I will have a ton of time into this "tub swap" when it is done... and then I won't want to sell it cause it took too much time, but my daughter really wants a CJ6 with a LJ frame/suspension under it, so that seems like what I will have to end up trading or selling/buying.
cb
