Build Thread 1985 CJ7 build.
Believe it or not (I don’t wanna jinx myself) but except for those three bolts. And now one screw (for a bracket holding the brake line) everything has come apart too easy. It’s like the PO didn’t know what torque meant. A friend of mine called yesterday and told me the same thing about the wire cup on the angle grinder. I was using a wire wheel on a drill. Gonna swing by harbor freight (the Target for men) and get a few for my grinder as well as a face shield.
the best is when the wires come out of the cup and brush at full speed lol had to pick a few out of my arms and thighs
Yeah. While I’m picking them up I’m gonna get a full face shield.
what primer are you using? almost looks tan
I'd recommend putting a lift kit on that creeper before things get out of hand. All BS aside while it is at this point I'd make at least one more firewall penetration; most likely at some point you will want to run a wire or two for some other reason. You can plug it off until needed. If you think you may be replacing brake lines this is a good time to get to the proportion valve.
Oh it’s definitely getting new brake lines. And without a doubt a new proportion valve. A lot of things are going to be replaced with new components. I should just open my wallet and keep it open lol
