Frame 1986 CJ 7 Frame
D.Ide
Raleigh
2021 Jeep Gladiator Willys
1976 Jeep CJ7 Base
Not the best looking welds but not the worst either.
Better than rust at any rate. Also check for rust on the inside (the section near the motor and Transmission ) by the brake proportioning valve as it rots there as well.
*anyone out there
Better than rust at any rate. Also check for rust on the inside (the section near the motor and transmission) by the brake proportioning valve as it rots there as well.
Thanks for the response. Will do. Jeep is $4000 and needs a little bodywork in the normal areas, ie rockers and rear quarters. Drive train is said be very good for the age of the jeep. 87,000 original miles. Feel like it’s worth the 2.5hr drive to for that price.
What motor and Transmission ? 86 is the last year and some of them had a vary hard to find wide track Dana 44 rear axle
Do you have more pictures?
What motor and transmission? 86 is the last year and some of them had a vary hard to find wide track Dana 44 rear axle
Dana 44 with T-176 . What do you think about the hold up of that frame weld over time?
Depends on how bad the rust was to begin with. Or if they were just reinforcing the frame in that area for a aftermarket bumper
With the combo you mentioned and if the Jeep is in at least decent working order then 4k is a good deal
Post pics
She's clean. Definitely a good deal
Deal keeps getting better and better
Swiss
$20.00
  10.0%
