Build Thread 1986 CJ7 Build
Congratulations on your success. Just a reminder though, the front range is a long stretch of mountains. Once you get South of Denver, there are no such requirements for emissions. Most of Colorado is not under that scrutiny. Congratulations again
Thanks guys.
-Now, time to work on the suspension and possibly upgrade the rear AMC20 . I have 2.70s in the axles now, which is crazy high. I plan on running a mild lift with 33" tires, so lower R&P gearing is necessary. Problem is, I don't want to spend any money on re-gearing the AMC20 . We've got at least 3 of them in the bone yard, discarded from prior builds in favor of other housings.
I know of a late '86 widetrack Dana 44 , but the guy is not quite ready to part with it. Also looking at Scout 44s too, but even those are hard to come by around here. Any ideas/leads out there? Budget is beginning to come to mind lately.
-But now, I see that the 2 little nylon flanged bushings (1/2" ID, go in the pivot of the booster linkage arm) are near their death. Where do I find these little gems? Internet search leads me to special ordering where the shipping costs about $50 for $5 bushings. Any ideas, other than searching the parts bins at the hardware/farm stores?
Those little bushings are called nyliners. They're common in Berkeley pumps in jet boats. Depending on size, Berkeley may sell them, or CPPerformance dot com. If they aren't a common boat size, I would look at McMaster Carr! But, a Google search of "nyliner" may get you more results. Good luck!
back in the day they installed residual pressure valves on drum brake systems im not sure if the CJs had them, I did not see one in my MC so I swapped out my prop valve to a disc/disc to make sure I didnt have an issue
Looks like your clutch linkage has some wear, it be a good time to weld the holes back round as well
Feb 1, 23:
-Knuckles installed with their new ball joints.
-New brake proportioning valve installed.
-New lower clutch linkage rod installed.
-New U-joints installed on front axle shafts, along with new seals. New spindles & hub bearings and seals installed as well.
-New tie-rod and drag link (heavier/1.25"dia.) and damper installed.
-Toe-in set last night.
Registered for the Moab Easter Jeep Safari a few days ago. Reserved a hotel as well. It's been about 20 years since I last went! So, we'll see if I can get this jeep dialed-in by early April.
It's great to see your progress and that your heading back to Moab! :chug:
Feb 1, 23:
KRUPP what are the dates for the MEJS event ?
