Build Thread 1986 CJ7 Build
It's something that was a popular mod starting 25 or so years ago. The rear YJ flares are a bit wider/longer, from front to back, than the o.e.m. ones.
When you experience tire rubbing at the rear of the opening when wheeling, trimming the sheet metal at the rear is usually the fix. About a 3" wedge of sheet metal removed at the bottom rear is usual, unless you want to start hacking through other sheet metal supports behind the rear fender.
When you do the trimming and try to re-use the o.e.m. rear flares, they tend to "kink" when you force them to be larger/wider radius from front to back.
If you re-use the original holes at the front of the wheel opening, the rear of the o.e.m. flare also pulls up, away from the bottom edge of the sheet metal, because it is now too short to cover the slightly larger wheel opening length. Some people don't like that look, so they go with YJ or even longer TJ rear flares.
I guess i probably won’t need that. Just graduated to 33s soon as I get them mounted.
The NP435 is a great Transmission and so is the T-18 , with the T-18 you need to inspect it to see what gear ratios it has one set of gears is not nearly as deep as the other set
The NP435 is a great transmission and so is the T18, with the T18 you need to inspect it to see what gear ratios it has one set of gears is not nearly as deep as the other set
Yea, T-18 is great, but Ford T-18 can be cranky. Granny gear is hard to find.
Man i love NP435s, very strong transmissions, i have one that i have been saving for my 42 willys
We saw plenty of them. Especially people riding in town with them. On soft trails I can imagine there could be damage. The main thing I noticed was the Jeeps are very slow out there. Dirt bikes and side by sides flying around.. one dirt bike flew by me and had problems right after passing me, he got sideways and stopped. When I passed by I said to the guy, you should be giving me $50 for not running you over. He said thanks.
Sorry for your loss. It is hard. I didn’t live to close for a few decades, but me being the baby we were very close and had a lot in common. Alzheimer’s and dementia are very bad. My mother in law had it. Just have fun in the Jeep and know she is looking down with fond memories.
Sorry for your loss its hard, i definitely recommend spending time with your dad while you have him
My '84 has two flasher units in the fuse box. One is for the blinkers and one for the flashers. The horn relay is in the harness about behind the headlight switch. And just a note: When I converted to all LED lights and replaced the flasher units with digital ones, I discovered that they are wired differently in the fuse block. With regular lights, the flasher units don't care about polarity. But with LED bulbs and the digital flasher units, the polarity does matter and so one of the flasher units required a polarity reverser to plug it into the fuse box. The two units are identical however.
Hmm? Maybe they changed in '85 or '86 to my setup with only 1 flasher at the fuse block.
Good to know TSB8C.
Mine is like TSB8C also
