Build Thread 1986 CJ7 Rebuild - Chasing my youth
...heater fan hole....wiring loom hole...and something else I’m forgetting...
knobs for windshield frame.... go on. I did a swap on the second one I did. It was a lot of work but worth it in my opinion.
Yes, going to swap fuel filler to passenger side. When I bought it, had a YJ tub already on with tailgate. YJ windshield squirters as well. Will be an auto Transmission .
Defrost, not sure how far along previous PO was. This was non running with no motor when I got it out of a storage locker. Did have all heater components installed. I’ve seen Shum’s and Gert’s windshield defrost mods.
I’m not quite sure how to spot a YJ windshield frame. Mounting holes were all
Lined up on previous tub.
Yes, going to swap fuel filler to passenger side. When I bought it, had a YJ tub already on with tailgate. YJ windshield squirters as well. Will be an auto transmission.
A YJ windshield frame will have a glued in windshield where a CJ will have a rubber gasket. The YJ windshield will have 3 holes in the far upper right and left for the spreader bars between the roll bar and windshield.
Well then it’s a CJ frame as windshield was pressed rubber gasket.
Thanks for the info! I figured it would have the roll bar mount holes if it were a YJ.
Awesome looking build. I’m closely following.
Very Nice! Great job!
Sent from my Pixel 2 using Tapatalk
What tank did you use. My next purchase is going to be a new gas tank. I want to go with a 20/21gal.
I went with a Crown. For $89-$100, can’t remember, wasn’t even a thought to try to reuse. Yes, smaller tank, prob could have tried to find a YJ tank with an in tank pump, but I know that there’s fitment issues with the CJ frame. Think Gert went that route, but had to widen the frame.
Yeah, I’m not looking to under-go a bunch of other mods. Gert is setting a paradigm with how much customization he’s achieved.
I think the larger tank will better support the sbc 350.
Your fuel system is looking good.
Yep, really scored on that one basically only some rust under the seam seller and some stress cracks around seat mounts. Fixed some wavy fenders and now time to start mocking everything up.
$190.00
  95.0%
