1st gear and reverse only
mgross13
I recently did a clutch on my step fathers jeep 77' CJ7 , with i believe a T-150 Transmission and a Dana 20 Transfer Case . while trans and transfer case was removed i replaced output shaft seals on transfer case, also oil pan gasket and mics. other repairs. i installed the new flywheel, bushing, clutch disc, pressure plate and throw out bearing.
after installing i dropped the shifter back in fired it up and found that i only had first and reverse. It would not go into nuetral and over to get to second or third. It will go into nuetral fine but has no "H" patern to it. I have read a few things about the shift rails beign out of sync, but i havent found anything showing how to sync them back up. anything would help.
