2100 carb ?
dalefan88
Crazy Sr. Respected Jeeper
thanks for all the info. i got the carb soaking and waiting to get rebuilt. this will be my first carb rebuild. hope i can figure out the linkage to.
good luck it looked like a nice clean carb
I've recently finished swapping a motorcraft carb for my Carter YF. If you're swapping from a single barrel to the M/C, you'll need a custom made adapter plate. If you're swapping in the M/C from a two barrel it's an adapter plate you can pick up from sumitt or jegs. Let me know, I'll dig you up the part number.
As for the hole, you'll just need to fill it with some silicon so that you're not sucking air in that isn't going through the air filter. Speaking of filters, do you have power brakes, if you do, you're pretty much limited to a 7" round. If you wants some pics, let me know, I'll put some of those up to.
One more thing, check the jet size in that carb. From what I've read and tinkered with 46-48's are the size you want.
2100 parts list -->> Motorcraft 2100 parts list - Jeep-CJ Documents and Manuals
One of the best 2100 / 2150 rebuild guides I have found -->> Motorcraft 2100 / 2500 Rebuild Guide - Jeep-CJ Documents and Manuals
now i have run into a coulpe of problems. i took the carb apart today and the carb kit he gave me dont match and i cant get one of the jets out. it stripped right where the screwdriver goes. any ideas on how to get the jet out, where can i get jets, and if this thing is a 2100. the carb kit says for a 2100d. not sure of the difference. this is the first time i took a carb apart and it wasnt to bad except for these to things. thanks
NAPAONLINE®
If the carb you got is from a 1967 Mustang, here's the rebuild kit from NAPA. You can order it online, or take the number to your local NAPA and have them order it. From my experience NAPA online takes forever, you're probably better off going to the local store, there's a slim chance they may have it in stock.
brass float;
NAPAONLINE®
thermostat;
NAPAONLINE®
If it doesn't work out let me know. I have a couple yards near by, I'll scrounge up a 2100 for you, all you'd have to pay for is the JY cost and shipping. There are so many fords and stuff, I could have my choice of bunches.
I saw like 5 york AC compressors the last tiem I was in the yard.
I should make a trip back get them and sell them to finance build stuffs....rambling...
Anyway, get me a year and model vehicle to look for and I'll scrounge one up if need be.
