232 still wont run in my 77 CJ7 ???
IOPort51
- Featured
- 5
- Media
- 458
- Garland Texas
- 1977 cj-5
2006 Toyota Tacoma
And just by coincidence you have the crappiest control module they ever put on a jeep. I am wondering if the parts house can test the one you have.Have you checked you ignition module? you mentioned that you did a tune-up a few days before, did you change the module? The reason that i ask is last spring i did a routine tune-up (jeep was running great just normal preventive maint.) changed plugs,wires,rotor,cap and module and after going to work a few times it started running like. I just thought i had gotten some bad gas at wal-mart. so i pumped the gas out and put it in the tractor. I cleared the lines and put fresh gas no change
Then i decided to look at the plugs they were all fouled but #1????? Checked spark it was weak, put old coil back on no change????? put old moldule back and bingo it ran fine
Took the new module back and had it tested :down::down:. the parts house replaced it, but i had them test it first and after testing six new modules and all of them failed i got my money back and went to napa and got a module. no more cheap ignition parts for my cj(bought generic low-cost parts and it really cost me in the long run)
