258 4.0 Head Swap Results
NO PROBLEMS to report I still swear by it being the best thing I ever did!I put about 20,000 miles on mine before the motor regrettably blew a piston skirt (I had a spare 401 lying around, no rebuild on the 6)
I never ran into ANY issues running this engine. I was pushing 11-11:5 compression with the flattys and never once encountered the dreaded pinging associated with high compression and regular gas.
Likewise, the previous misinformation can just be thrown out the window. The valvetrain between the 4.0 and 4.2 is identical except for the valves themselves and there may be a slight variance with the pushrods, but I've ran into that between different years of 4.2...so that's not an issue. The rockers and pivots are all the same. Springs...no issue.
I used a TFI ignition, so I didnt get the test the "theory" of worn dizzy gears.
Pound for pound, and dollar for doller I think this is the best modification that can ever be done to the 4.2. It makes it a whole different engine![]()
My 73 rods were hollow. Where did you hear that? How would the oil get up there then?
I'm collecting parts now to do this swap. Got my exhaust manifold. Still trying to track down a head, considering the clearwater head with the welded water holes. Seems like it may be cheaper after the $200 junkyard head then getting the head rebuilt. Valve cover will be the easy part to get. I'm trying to figure out if I want the original cover or get the aluminum blue cover to match the engine.
I wanted to add this bit of infor for the spacers for the different size bolt holes, I didn't see this in here so here it is. Heres a link for 1/2" spacers for the 7/16" block holes. Summit racing has them. Part #TFS-51400419
Trick Flow Specialties TFS-51400419 - Trick Flow® Head Bolt Bushings - Overview - SummitRacing.com
I take it you don't have a pick n pull type junk yard near by? I nabbed my new head, valve cover, and even the push rods and head bolts really cheap by pulling it myself from a 1995 Cherokee.
Thanks for posting the link for the spacers. Fortunately I didn't need them since my block is a 1979 that takes 1/2" head bolts.
We do have one but they want $200 for head and $50 for cover. After I get the head rebuilt, I might as well order the clearwater one and be cheaper with welded ports.
It took me a bit of searching to find these so I figured anybody planning to do the swap looking at this thread will now have more info in one spot.
I don't remember the exact amount of preload that the lifters call for, but with adjustable rockers, it's between 1/2 and 1 rotation of the nut, so it's not much. Hydraulic lifters are pretty forgiving and will allow and compansate for different amounts of preload, as long as it's not too much. If the push rods are too shorts, you'll have a lot of clatter.Yeah I would have to pull the head myself. I deen looking on craigslist but timing never works out. I seen a bundh of 4.0L engine for cheap. Now that I decided to do the swap I can't find any. And I'm in Hawaii so its a limited search area..
How did you go about measuring for the correct pushrods? I'm not to sure on that or if theres anything special for putting the rocker arms on.
Your 0630 head is pretty much the same as a 7120 except it probably doesn't have the sender hole drilled behind the valve cover, and the exaust ports look a little different, but they flow just about as good, and should take the same gaskets as far as I know.So I finnally got most of my parts together to get started on the swap. I do have one question though. We I was getting the head, the guy said it was #7120 but when I got it, it was # 0630. I alrady got a valve cover from a 92 XJ and was wondering if anybody knows if that valve cover will fit on the 0630 head? When you look up gaskets, thay stop at 95 and have a different one listed for newer years. So either I go and buy another valve cover from a new XJ from the junkyard (I'm sure they won't take the old one back in exchange) or use the 92. Any suggestions?
I would too, no question, but when we do multiple changes it is not possible to attribute the performance to any one thing.
I don't have fancy test equipment but I do have a hill. It's about 1/8 mile 20 degrees and paved. I start at the bottom in 2nd gear and time the distance with a stop watch. As long as I am doing one thing at a time I can get a pretty good idea how much bang I got for my buck. We need to establish a personal constant to measure against.
I am not saying the head swap is a bad idea, it is a good one. I had a cracked 4.2 head and this was the very best solution. I am saying there is a lot of mist and smoke blowing around this and a lot of other modifications because we can not document the results in measurable quantity.![]()
He might have a 232 instead of a 258?
Well I finished my head swap finally. So here's what I went with: 0630 head, 4.2L pushrods, JBA Header, new cat and flowmaster 40 series muffler - 2.5" pipe. with a howell TBI (was installed before the swap).
Heres a link to a small video with how it sounds.
258 w/ 4.0 head - YouTube
Thanks for all the help guys.
