258 not happy with the Holley.
mitchelllogic
- Edmonton
- 1982 CJ7 Returned to stock (Sold), 2002 Jeep Cherokee Sport stock (Sold), 1985 CJ7 - Restomod
Well, I'm glad I read your post ! I would have never thought the 258" would have enough CFM to get a 4 barrel working properly.
Exactly!Some things to consider:
Using 80-85 % as the engines volumetric efficiency a 258 inch engine will use 371 CFM. At 100% VE the 258 would use 447 CFM. - calculated at 6000 RPM maximum.
A 4-barrel 525 CFM vacuum secondary carb will have approximately 260 CFM on the primaries and secondaries. It will basically be running on a 2-barrel and only using the secondaries when needed and because they will be vacuum opened they will only open for what the engine will need. A mechanical secondary carb would be overkill, but not a vacuum secondary carb.
The Motocraft 2150 and Autolite 2100 2-barrel carbs came in different CFM ratings all the way down to 190 CFM so it's possible to find a 2-barrel that will have a more exact CFM for the top performance of the engine. The 4-barrel on the other hand will allow the primaries to be smaller and give better lower RPM performance before needing extra CFM at top performance.
Also of note is the intake manifold that mitchelllogic is using. That Offenhauser is engineered to have an extremely good flow on the primaries - they are separated from the secondaries until the runners reach the head.
100kmh = 64mph ishHey mitchellogic what the heck is km/hr ? Not very easy to figure out mpg.![]()
Set a cup of water on your fender.
Check your park brake is on.
Shift the transfer case to neutral.
Block your tires.
Start your rig.
Observe the ripple pattern in the cup.
Stop the engine.
Mark your current distributor alignment by scribing a line on the base of the distributor and engine.
Loosen the distributor hold down bolt but leave some resistance on it so the distributor doesn't flop around.
Get a friend to start the engine while you hold the distributor in place.
Slowly, very very very slowly start rotating the distributor in small increments while you watch the ripple pattern in the cup.
If it gets worse (choppy or uneven rings) STOP and rotate back then the other direction.
You will find a "sweet spot" where it sounds right but the ripple pattern, once even and low ripples, will get you spot on. Tighten it. (Carefully as it's hot now).
I haven't used a light for a tune in years.
(Different story if you had removed and replaced your distributor).
Be careful with a running engine. Hot parts, poor insulation on old plug wires, an un-guarded fan, shifter slip, all can cause severe injury or death.
Sent from my Pixel 2 using Tapatalk
Never heard this one before. Does beer work, or does it have to be water...?
Warm weather, cheap gas, and a Jeep? I am starting to think I should come visit.....and stay. Jeep and I just made it through a week of 40 below weather!Actually I knew those conversions from driving back and forth to the southern boarder of Mexico in the early 70s. I was just messing with you. I have to admit I never was good with the litre though. Glad I'm not having to pay for that expensive Great White North oil. Only paying $ 1.96 yesterday![]()
You sir may arm chair in my garage!I'm thinking a cup of water first thing, then when running just right, very nice single malt scotch, the beer might get to warm in the beginning
Might be able to handle a visit in spring or fall but I would melt and die in your summer. Went to Vegas one summer and just laid out on the hotel A/C. Seriously thought I was going to have brain damage from the heat. I didn't know a person could sweat like that. A Brita water filter in the flesh. Don't understand how you do it.Yeah I don't know how you handle that cold, but then you would probably say the same about here in July & August. The a/c runs probably 50 minutes an hour.![]()
