304 compression?
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
After dribbling the question of swapping out my AMC 304 for a 360 I made the decision to make the change. But while getting ready to remove my AMC 304 I decided to do a compression check. More to know what to tell potential buyers and to have a general knowledge of the condition of the engine. All plugs were wet, but the thing hasn't done anything but idle for a very long time. The engine is producing 138 lbs. (3 cylinders), 132, 135, 128 and I can't get to the two by the battery with this gauge. That didn't seem to bad until I checked my Chilton's manual (piece of
the thing doesn't even mention a T-15 Transmission ). I hate that manual, but the charts are copies from the shop manuals so at least they are reliable. It says that '72-'75 should have AMC 150 lbs. MINIMUM and the '76-'81 should have 120-AMC 150 lbs. Quite a difference if you ask me. So, is a '75 with 129-138 lbs. pressure an engine in need of a rebuild?
