304 TBI conversion flooding
mstevens61
- Pocasset
- 1978 CJ7, 304, quadra-track, amc 20, D30
Former
1984, CJ7, 151, T5, D300, AMC20, D30
1983, Wagoneer, 360
Hello fellas, been reading the forum for quite some time, but first time posting.
I recently did a fuel injection (GM with DUI computer controlled advance from AFI) conversion to my otherwise stock AMC 304 (CJ7 - fiberglass body). The conversion went well and was completed in single weekend. The jeep was a daily driver prior to this conversion, it usually ran good but on occasion with idle very high and on other occasions it would stall for no apparent reason. I tinkered quite a bit but in the end wanted better drivability and cold weather starting. The jeep lit right off on initial crank and idled smooth but high. It didn't really except much acceleration (it would bog down and stumble) but I figured it needed to "learn" itself (according to AFIs documentation). I tried to take it for a short ride, it back fired a bit and stumbled, the progressively got worse until I limped back in the garage, (about 5 more min and 1/4 mile of driving/ running).
A couple things Im certain I had wrong right from the get go:
I did not hook up my PCV and upon arriving back in the garage had a massive oil leak from the front seal, which was already leaking a little and I latter found out it was not installed properly anyway.
I also believe on my initial running and driving I had the timing to far advanced, 10 btd, then plug the timing control wire in. (should be base 0)
It cranks, starts, and stalls in a few seconds. All the while seemingly pumping a tremendous amount of fuel, which does not seem to change between cranking and running. Plugs are fouled after several attempts (they have been pulled and cleaned several times). The inside of the tbi is wet with fuel and after several attempts there will be a puddle in the floor of the intake. It never develops good vacuum, presumably because it is running so rich it is flooding out. I do have a scan tool and a hand held vacuum gauge.
I have been able to get it to run albeit very poorly and again with little vacuum on one injector, upon plugging the second injector it revs up, smooths out and stalls, all the while gas spurting out everywhere.
The injectors are color coded green which is recommended for a 5.0. The spray pattern seems ok, but excessive.
It has been over two months since my completeing the install and with the guidance of AFI this is what I have done (btw AFI does not seem convinced that it is flooding???);
Checked and rechecked timing
Checked for spark on all wires, and visually checked spark with a plug removed
New wires and plugs (twice)
Installed an inline fuel pressure gauge (running at 12psi)
Check and rechecked grounds and ran additional grounds
Scoured the engine for vacuum leaks (removed all unnecessary vacuum lines, and plugged)
Applied an artificial vacuum to the map sensor
Replaced sensors (Water, Map)
unplugged each sensor (IAC, MAP, O2, Water, TPS)
Replaced the ignition module, coil and pick up coil in the DUI distributer
Added a relay for distributer power to be sure it was getting plenty of power right from the battery
Check compression, all between 115-126
Fixed front seal, droped oil pan, check timming chain
Pulled valve covers, all valves seem to be operating properly, i did not measure lift
Pulled the intake manifold, inspected lifters and push rods
Tried removing the crank sensor
added a ground for the distributer right to the block
Tried two diffrent ECMs and three diffrent chips, one of which I was told has a fuel curve similar to a 4 cyl.
I put the old carb back on, I got similar results, and even thought I heard some valve train noise (which is why I pulled the intake). admittedly I did a half *** job trying to get the carb back on there and running, maybe I will try again.
I have changed the oil twice through all of this and both times it was terribly gassed up. Through all of this I have seen little change and certainly nothing that corresponds to anything I have done. Occasionaly it has run a little longer but never more than 30s. It starts floods and stalls in a few seconds, so fast that I can barley get any usable data from the scan tool.
At my disposal I have the scan tool, a hand held tack, a hand held vacuum gauge, a vacuum pump, a multi meter with back probs, an IR gun, fuel pressure gauge, and a timming light.
Im stumped! I feel defeated. I cant go back, I have spent an addtional $1200 on parts and tools. My old carb sucks, my new distributer is computer advanced and my old ignition module is prob junk too. The guy at AFI is getting tiered of hearing from me and clearly hasnt helped.
This was a daily driver prior to this, and i need it to be again.
Sorry this is so long just wanted to get all the info out there, and didnt want a bunch of you guys wasting your time telling me to do something I already had.
Thanks in advance for your help.
Matt
Matt
