304 valves
304 valves
grunt
Connecticut
1979 CJ 304, 400 automatic
How do you adjust the valves on a AMC 304 engine. Is there a sticky here? I tried the search button and no luck. Appreciate the input...
You dont adjust them the rockers bolt down and thats it :chug:
How do you adjust the valves on a 304 engine. Is there a sticky here? I tried the search button and no luck. Appreciate the input...
Unless your engine has been modified like mine or C.J.'s ;)
If you are getting excessive valvetrain noise, check for worn rockers, pushrods, and pivots.
