4.0 on a 4.2 Options
Rescue Diver
Full Time Jeeper
- Kansas City
- 1979 CJ-7 with a fiberglass body and 1982 wide track axles, 258 I-6 with a 1995 4.0 head, HEI distributor, Motorcraft 2100 Carb, T-18 wide ratio tranny, Super Lift Springs and 33s, a 1997 BMW 328i, and a 2010 REDLINE CONQUEST TEAM Cyclocross Bike. :)
Yeah, I'm right there with you. I plan on tearing into the donor 4.0 this weekend. I'll need to get the head work done.
It will probably take me a few weeks to get that done. There is a machine shop local, but the guy I talked to said they wouldn't do any work on it if the water jackets were filled with JB weld. They would have to drill and tap for freeze plugs, and they are not siue if they have the right bit and tap size. I am going to have to call around for a few other shops.
Just let me know how your project goes. Looking forward to it.
Thanks, Dan
It only took my prefered machine shop a couple days to do mine, but I waited until I got it back from them to do the water jackets with JB weld. After reading countless threads on many different forums, I have yet to hear from anyone that had a leak when they filled them that way. Even the stock 4.0 head gasket covers those ports, so it's not certain that we would even have a leak doing nothing at all. I read that the problem can arise from some AMC 258 i6 / 4.2l blocks being slightly narrower on the manifold side than on a 4.0 block, so the head hangs slightly over the edge, leaving these ports too close to the side of the block. I took care to clean the ports well, and the JB weld is 3/4" thick blocking the ports. They won't leak. I'll know more about how well it lines up with the block when I finally get to bolt it on this weekend. I've heard they changed the block in 1980 and newer 258's so maybe my 1978 block casting is wider? 1980 is also when they changed to 7/16" head bolts from 1/2". They switched back to 1/2" for the 4.0, so I can just use my stock 1/2" head bolts without spacers. Can't wait to hear it run!
