4.2 to 4.0 head/MPI is underway!
Sasquach
Crazy Sr. Respected Jeeper
- Media
- 35
- Santa Ynez, Ca.
- 1978 CJ5, 258 w/4.0head, Mopar MPI, P.S., P.B.,Tilt wheel, No stereo, t-18, t-20, amc 20, dana-30 w/tru-trac, Warn full float w/locking hubs & Detroit locker in the AMC.
1964 CJ3B, 4-134
1952 M100 trailer
The swap only brings you up to a little over 9 to 1 compression. I just run regular unleaded and it doesn't ping at all. Just make sure you set your ignition timing so that it's advanced as far as it can go without pinging. It's really that simple. I've put a lot of miles on mine and haven't had to do anything other than change the oil every three thousand miles. It still runs as good as the day I bolted it together, and I never have to worry about maintaining highway speeds into the wind on long uphills. The greatly increased gas mileage is also a huge bonus!
Good Luck!![]()
If you go MPI the distributor timming is computer controlled.
