Build Thread 73jeep's CJ 5 rebuild
73jeep
Whitefield, NH
73 CJ5 TBI 258 t14 d20 - Rebuild in process
08 Duramax Crewcab 4x4
Defenately need a good frame in any rig. Smart start!
A lot of guys are fabing their frames up now. I have heard of some DMV code issues in certain areas of the country! Just throwing that out to people who may be doing this type of frame!
I had a 74 myself! I really like the intermediates!
I like carbs. I know fuel injection is nice, but you can usually fix a carb enough to get you home!
In my opinion the best jeep carb is a MC2100 and a Quadrajet!
Any thoughts on what you want the finishe dproduct will be?
Nice project!
Thanks,
I already checked the inspection rules, it just needs to be made of the same material as the original and not effect original suspension geometry. I am also using a section of the original frame ( the portion with serial number stamped) so this qualifying as a "repair".
I do plan on using a mc2150/mc2100 I used to run one on this CJ the fuel injection is nice but I have more issues with it than anything else.
I would like to know more about your injection issues. Flooding is usually caused by a bad coolant temp sensor or fuel pressure regulator.
I wouldn't listen to northwestcjer his head is backwards I know this for fact because I wheel him all the time. :D
Looks like a ton of fun!
It's not either one of those, on startup and shutdown the injectors hold open and flood the motor. That along with other issues inherent with tbi on a strait 6 makes me want to switch back to a carb.
Just curriouse? is it a name brand system? (don't need to give a name)
I have been hearing a few issues with a popular EFI system!
I live the MC2100 1.08 ventury! I run it on a AMC 258 i6 / 4.2l and have no issues. I ran it on a 74' AMC 304 also.
My opinion. to go EFI, I think to go EFI, I would get rid of the AMC engine and do a donor 4.3 V6 complete from a running rig.
It's a home built system. Based off the 4.3 tbi. If I was going to do efi again I would swap in an efi engine and not retrofit...
Right now I'm looking for something a bit more reliable.... This current system has left me stranded many times.
Being in the middle of the woods I would like something I can fix with a screwdriver not a laptop.
I ordered the steel yesterday. 48 ft of 4x2x.125 rectangular a36 tubing.
I'm still trying to decide of I want to cap the ends of the tubing, attempting to get them air tight or leave them open to have accesses to wash any debris out. What is the forums thoughts on this, keeping in mind I live in northern new Hampshire and road salt is a way of life here..
Cap the ends!
If the other end was open so you could wash all the way threw, I would say leave them open!
Looks cleaner, also!
My opinion!
I should be placing an order tomorrow for new spring and shackle hangers tomorrow. I was hoping to reuse the originals but they were too rusted.
Any comments or advice is appreciated!
