74 CJ5 Rock Rails
Just couldn't find a set of rock rails/sliders that I liked. My jeep tube is fiberglass so hooking to the tub is not an option. So decided to build a set . I started with 1.20 wall DOM tubing. I liked the 1 1/2" diameter so I used that size. Neighbor is a really good tube bender-so he bent me a set of outer bars. The lower straight bar is 43 " long and that length looked good between the flares. I really did not like the idea of just attaching to the frame, another buddy gave me a good idea. The rear and middle out riggers have a vertical tube that goes through the floor and attaches to the cage bar that runs from the front to the middle cage loop legs. The front out rigger is welded inside what appears to be unused body mount supports (1/8 thick on top and both sides, and, about 10" long-worked great super strong). I tested it with my high lift-picked the jeep right up-not even a hint flex/movement in the rails. Bring on the rocks!
