75 CJ6 grill bottom?
danc9
Clarksville, IN
1975 CJ 6, 258 I6, T-14, Dana 20, Dana 30, Dana 44
I tore apart the front end today. The bottom is rusted and broken and missing some parts?
It looks like there is something missing in the front????
Center mounting bracket is broke off......
Where the welds align, it looks to go about here? Many thanks to any one who can help. If you got one off that you can get a picture of it would be great!
DAN
There are two rubber donught type bushings that go in there. Bear with me a few moments and I'll post a pic. I just happen to have them out and in my garage.
Ok here you go. 1 will go in between the grill and the frame and the other goes underneath. They are there so the grill can vibrate a bit and not crack. The 1 on the right has that bolt you showed going thru it its just cut off.
And now that I look a little closer your grill should look like this. Your missing a small piece of sheetmetal.
Thank you very much!
DAN
:chug: Its gonna be a bit of work to get that CJ6 on the road but it'll be worth it. :cool:
