Build Thread '76 CJ5 351w Swap
Ugh
Well, I'm gonna come out and say it...I'm a bonehead.
Bottle of Woodford Reserve to the first person to correctly guess what I did that led to this minor disaster.
Not the end of the world...just going to require a new starter. This one is toast.
Still not happy about that rear main seal leak...
Sent from my Pixel 2 using Tapatalk
The wrong starter
Boooooooo!
Ok an autozone rebuilt starter. I had a water pump self destruct in 3 miles
Can't wait to hear what went wrong with the starter. I just had to replace one on a bucket truck that I borrowed.
Definitely not a generic rebuilt starter. It s a Tuff Stuff PMGR starter.
In my excitement to get the starter installed and finally finish the wiring a couple weeks ago, I never checked clearances on the starter gear and the flywheel.
This starter needs a 1/4" shim to clear the flywheel. Dang thing was never disengaging and now it's toast.
Did I mention how not happy I am about the rear main seal leak?
Ok, so it's not a rear main seal leak. Just a minor oil leak at the back of the pan after initial heat cycles. Also, I had too much oil in it. Turns out this motor and stock style pan only likes 4.5 quarts. Took care of it and no more leak.
Took the old girl out on her maiden voyage today and she did well.
Couple things to address:
Pinging in the engine during hard acceleration. Need to smooth out the timing curves on the Sniper. Not a big deal. Idle, idle air control and AFI are good to go.
The Transmission is really hard to shift. Did some troubleshooting, and turns out that the clutch isn't releasing all the way. I backed out the adjustment in the slave cylinder rod as far as I can and it's just enough, but the pedal is on the floor to disengage. Just need to make a longer slave rod and I'll be good.
Otherwise, she runs great!
This is one of the best feelings I've had in a long while. It's taken a lot of hard work and planning to make it to this point.
I took it out to the local lunch place today and folks came out to drool. It was awesome.
The transmission is really hard to shift. Did some troubleshooting, and turns out that the clutch isn't releasing all the way. I backed out the adjustment in the slave cylinder rod as far as I can and it's just enough, but the pedal is on the floor to disengage. Just need to make a longer slave rod and I'll be good.
One of the reasons we have CJ's. They command attention.
What topped it off was the white '74 CJ5 that was waiting in the parking lot for me. It was owned by a young kid and we stood there in the lot talking CJs for about an hour.
He had a rebuilt AMC 304 with headers and purple hornies. It sounded great. I about floored him when I started mine up. He was convinced I had a 401 hiding under there.
