Build Thread 79 CJ7 "They’re coming to take me away aha"
Shift forks. From what I can gather, after some internet research on shift forks, the material seems to be, are you ready, nylon. My T-15 has some problems in this same area and I've considered getting some nylon stockings, melting them down and trying to dip my forks myself. Since my fork pads are all but gone, it certainly couldn't hurt. For the T-18 you might be able to replace them with the newer alloy forks. Which brings up another thing. My jeep expert says that the older close ratio T-18's have forks like yours. The newer and desirable T-18 has the alloy (aluminum) forks. Which begs the question, do you have the more desirable T-18 with the very low first gear?
Love the write-up so far.
The HEI everybody seems to have decided are junk can be made good again by simply using your old distributer gear. I run a DUI Distributor and have absolutely NO complaints with it. Everybody says that the DUI gear is compatible with the stock gear, but just to be sure I used the old gear. Compared to what you've done this is an easy thing to do.
Hey there folks - glad to see it's all moving in the right direction...
I will throw out a caution flag though...without starting another religious discussion on 304 ignitions, be very wary of any HEI you ordered, you can have distributor gear vs. cam gear battle royale...
I would get a stock distributor from NAPA for your year/model Jeep (has appropriate cam gear), then add the cap adaptor and MSD cap like I have. You already have a Motorcraft ignition unless the PO removed it for an HEI. If you're still Motorcraft, then get what I have (or BusaDave has) and get some high-end MSD wires and be done. Myself, TeamRush or Dave have some experience with this. TeamRush lives here near me and he can call you if need be.
Thanks 007, already anticipated this problem and will be switching the gear from the old distributor to the new one. Put a micrometer on each distributor, and everything matches. I read in one of Dave's posts this is kind of the ounce of prevention approach.
Your definitely catching a bad break here. I'm stripping the Limited this weekend to make room for the Scrambler. I have a gas tank and a power brake system id gladly donate to the cause. Just have to figure out how to get it there
Thanks Pete, kind of looks like the chrome booster and bracket we bought is going to fit. I used the epoxy on our farm tractor tank 2 years ago and it is still holding. We appreciate the offer, and if things do not work out, we may take you up on your offer. :chug:
[qus have forks like yours. The newer and desirable T-18 has the alloy (aluminote=Hedgehog;208030]Shift forks. From what I can gather, after some internet research on shift forks, the material seems to be, are you ready, nylon. My T-15 has some problems in this same area and I've considered getting some nylon stockings, melting them down and trying to dip my forks myself. Since my fork pads are all but gone, it certainly couldn't hurt. For the T-18 you might be able to replace them with the newer alloy forks. Which brings up another thing. My jeep expert says that the older close ratio T-18'um) forks. Which begs the question, do you have the more desirable T-18 with the very low first gear?
The HEI everybody seems to have decided are junk can be made good again by simply using your old distributer gear. I run a DUI Distributor and have absolutely NO complaints with it. Everybody says that the DUI gear is compatible with the stock gear, but just to be sure I used the old gear. Compared to what you've done this is an easy thing to do.[/quote]
[FONT=&quot]Thanks Hedgehog, actually I have a similar idea. Not going to happen before the trip, but this winter I plan to melt down the nylon slides from a snowmobile suspension and try that. It’s designed for friction contact, so what the heck! And we do have the granny low ear, 6.32 I believe. [/FONT]
One other thing on the Transmission , Posi looked up the numbers for us and it turns out that this transmission is out of a 1978 J10 or J20 truck.
If you plan to keep the HEI swap the drive gear from the original distributor to the HEI. Just remove the roll pin and it will slide off.
Sorry for the cobbled together mess but this thread is a great read. Love the Star Wars references but I always wanted to be Darth Vader more than Luke anyway. :D:chug:
Thanks Pete, Sometimes drifting off into a universe from long is the only way to cope with this disaster! I only wish that I could add a light saber to my tool box to make some of those............necessary adjustments,...... to correct the PO's mess easier. (and more fun!)
This thread is the gift that keeps on giving. :D looks like you'll have the majority of it rebuilt before Colorado. Question : Did you buy the power brake lines from the master cylinder to the proportioning valve pre bent or did you bend your own? If pre bent where did you get them?
Gotta keep up the humor to keep from goin crazy:rolleyes:. I bend my own, but Morris has complete sets starting at around $115. I have another source for brake lines at home. I dont know if they sell individual lines though. I will send it to you when I get home from work Friday.
Loving the progress. I know you'll make it and have it on the trailer in mid July.
Thanks 007! Sure hope that you are right, really looking forward to seeing everyone again.
When ordering up the clutch parts go with the Heim Joint conversion. Or you can do it yourself. Makes for a MUCH nicer clutch feel and isn't crazy expensive.
OUTSTANDING :notworthy:
Great story!
Nicely done .... So, I hate to bring this up. ...... I had exhaust pipes that came out in the back essentially where yours do. Hate to say this but it was awful. The blunt nature of the rear end of a CJ creates a vacuum that fills with exhaust fumes. If you have a nicely fitting top you might get away with it, but in an open CJ the fumes were terrible. I had to add bends to allow the exhaust to exit at the rear corners which put in the turbulent air flow and eliminated the problem. I hated to do it, my CJ came with great looking square tips and the sound was VERY hot rod like, a nice burble. Cutting off the tips and adding a bend at the end changed the sound more than expected, but at least I don't stink of exhaust anymore. I hope you don't experience the same problem, but be aware.
:) RED! That's a lot of red for what looks like a flat black jeep! I like it!
$150.00
  75.0%
