Build Thread 79 CJ7 "They’re coming to take me away aha"
I had the same questions about vacuum advance. I think that by the book, Posi is right but in some situations manifold vacuum is better because you can get quicker advance if that's what you need. I switched mine from ported to manifold and I could tell a difference in throttle response.
I think that the situations where manifold is better is when you're trying to compensate for something else regardless of whether you should be or not. In my case, I'm tuned for 10,000 feet but I'm sitting 400 feet. When I actually get to 10,000 feet, I might decide I'm not set up to where I need to be. .
I was simply posting to let him know he was checking engine vacuum at the wrong port (if the distributor advance was set up to factory specs).
Hey no I didn't mean to come across that way... You're exactly right, I just meant to give an example of manifold vac. My apologies.
Not a problem, I didn't feel my first post was clear enough.
Oh, I'll give you a call tomorrow on what we talked about.
10-4
Awesome work. So so happy for you both! It's been a long time coming eh?
It's gonna be a great trip!
Said it before , "I love your shop." When I needed to bend a Transmission cover I used my thigh (leg). When you need to do the same thing you just go to your handy ENGLISH WHEEL. OMG that is a well equipped garage.
You've gone a long way, and have a well equipped jeep in very little time, very impressive indeed. I hope you have a memorable week in Colorado.
Well done!
You two should be proud of what you accomplished in such a short time. That was definitely not a "turn key" CJ to say the least. Great work and can't wait to see the trail ride here. :D
Definitely not turn key! Maybe we should see if Chip Foose needs help on "Overhaulin";) I never thought we would make it in the amount of time that we had.
And the news keeps getting better! (really!) I checked the alignment today and found that the toe was set at almost 1/2" toe in. Set it around 1/16 to 1/8 toe in and that made a great improvement in the "wandering" while going down the road.
As always, great post! Love the boot, I'm going to need to do one myself. The new replacement boots, one of which I have, simply don't last. Mine cracked in less than 6 months.
How do you like your Twin Sticks? Love mine. No more fighting with the Transfer Case and barking up my knuckles. I still have my pills in place so shifting needs to be done in perfect order, but no matter. A short movement of the levers gets the job done, quick and accurate.
Well done. Looks great!
Well done!
Hope for a speedy knee recovery.
