Build Thread '81 CJ-7 Laredo build
Sorry to read about that damage. And the delay. That totally sucks. And hopefully you are right and that you don't have any more bad luck. Only good luck.
Well my new water pump gasket should be in by the time I'm home from work. I'll know which way my luck is leaning by dinner time. :D I'm pretty sure I used up all the bad by now.
So I am guessing you DIDN'T use up all of that bad luck.
Well I hope the 82 appreciates the time and attention you are now able to give it.
Peter-You need to educate that 'wrench' of yours.:eek:
All AMC made Jeeps/cars with manual trannys, will start in gear. :D
But mine is an automatic. ;) Previous owner switched it to a floor shifter instead of on the column further complicating matters.
Aw-YES, that could be an issue then(and 'exciting' too:p). :D
More pics please :D
And on the way home from camping/wheeling the "new" engine let loose. :(
I'm now parting it out but saving the Frams and axles along with some sheet metal to start my pick up project
