Build Thread '81 CJ-7 Laredo build
Took a little time off but restarted today. Got all the belts and pulleys lined up correctly and tight. My poly engine mounts are in and tight as well as the exhaust being hooked back up. No pics but things are going on . I ordered the carb and it'll be here Wednesday. If that's not the day she rumbles to life it'll be that weekend. Can't wait!:chug:
Fingers crossed. :chug:
Thanks, it's taken longer than I thought but it's been fun to work on again. I know tomorrow's Mothers Day but I'm coming home with something I've wanted for quite awhile. Stay tuned. :D
Peter-bet you don't get much sleep tonight. :laugh: :poke:
Great :banana: I have found that Marvel Mystery Oil(MMO)to be a great lube for air-tools and have used it in mine for decades. Only need 6-7 drops of oil in the tools inlet.
Drain the tank OFTEN ;)
Your only regret will be, that you didn't get'em sooner.:poke:
You got it. They tasted their first few drops of MMO yesterday!
[emoji106][emoji106][emoji106] happy uncompressing!
Wooly
Thanks. Tonight's the night I try and fire it up. Can't wait! :chug:
You want to adjust the pressure regulator on the compressor. So the highest drawing tool(impact wrench), while running, doesn't exceed 85-90 psi. Any higher, and it will beat the tool to death.
BTW-You have only just started buy'n air-tools...........:laugh:
Best of luck with start up! :chug:
Start up was successful! :chug: Two loose hoses and 180 degrees out of time. :rolleyes:
As for air tools I was still shopping in the parking lot lol. :D
Out :censored: Standing! :banana:
When's the first road test?
Awesome Pete! :banana: I have a set of air tools from HF and a set of Impact sockets too. No problems in over 5 years. My compressor though I went with a big mother, and sometimes it's still not enough when sanding or grinding. Impact is always good. I love my 3" cut off wheel tool, use it a lot. I also use an angle die grinder for a scotch pad sander. Really nice for cleanup work. Have fun with you new tools! :D
Just a thought, does momma get presents on father's day? :poke:
