Build Thread '81 CJ-7 Laredo build
Sold enough stuff to get the Tie Rod / Drag link kit and the Goferit flip kit. Gotta ship the stuff out and wait on the money order ( Ive dealt with this person before :) ). Hopefully I can have my brother tack the flip kit in the weekend of the 12th.
So I basically traded a Slate Blue dash pad with a crack , a carter bbd with stepper motor and a set of Yj fold n tumble brackets for the beefy drag link , tie rod and flip kit. I can live with that. :chug:
sounds like a good trade to me.:chug:
So did you get the kit yet Pete?
How do you like it if so? They look more awesome in person!
:D:cool:
~ Jr
:D:cool:
~ Jr
Just ordered it up right now. I was waiting on the check for the parts I sold to clear. Sould be here by Friday. Thanks for the link. :chug:
Good deal, progress at its finest.
Sent from my DROID RAZR HD using Tapatalk 2
Ha , I like the simpler jobs. :D When it comes to painting it the body color of the Limited it wont be nearly as easy. There are small nicks and dings that I'll have to take time to fill in for sure.
Hey Pete, how much sanding did you do to the top? I'm planning on painting mine the same color as the tube. I'm just wondering how much it needs to be prepped first? I've never worked with fiberglass before. I'm not looking for that smooth body type finish, just want it to look good and match the tub. I like the door change. I'd like to do that sometime in the future, but the cost of doors is outrageous. Rod
2nd peanutbutter on the prep work. We want to paint our tops too!
I like the color of yours with the white. :cool:
I only spent about an hour sanding it with 110 grit then a quick once over with 220. I went around the contoured areas in the rear with a red scotch brite and then by hand with the 220 again. I just used Rustoleum rattle can gloss black then. It looks good now but we'll see how it holds up. The rattle can paint I used before faded pretty quick. The only reason I used rattle can again is I know it will just be getting repainted in the Spring when I paint it Slate Blue Metallic to match the Limited .
Using this top and doors was mainly to save room in the garage. Having two hardtops and two sets of doors took up way to much room. I do prefer the paddle style handles though. My rotary ones didnt come with the correct door latches either and their a p.i.t.a to find.
The only reason I used rattle can again is I know it will just be getting repainted in the Spring when I paint it Slate Blue Metallic to match the Limited.
QUOTE]
Mine will be Duplicolor Midnight Blue. I plan on repaintig the inside white though. Have you thought about what you will do on the inside? Rod
There's a nice looking Limited headliner listed in the 3rd party sales over on the Srambler board. You see it? Kinda pricey, but you could buy it and then sell yours!
Thanks for the heads up but yup , I saw it this morning. :) If mine was damaged Idve grabbed it but I cant afford to hoard. :D
