Build Thread '81 CJ-7 Laredo build
Yea, you gotta take it easy on them knees for awhile. With my replacements, it took a full year to really feel normal again, so you should be back up and running before to long. :) I know you don't want to hear this, but weight is the hardest thing on knees. With me it's a catch 22. I need the exercise to lose weight, :confused: but I can't run or jog, :o so my weight has gone up, which is bad on my knees. :mad: I've found that my recumbent bike is the best exercise with the least amount of impact on my knees. :D Might consider getting one. Used ones available all the time. :chug:
PS: Glad to see you back on the Jeep.
I hear you. I've been struggling with my weight since I quit smoking years ago. I have a treadmill I was trying to use but I needed to be on it for an hour a day to get any results. That bothers my knee like you mentioned. I had the best results when I was riding bike 1/2 HR to 3/4 HR a day. A recumbent bike may be the best for me along with a better diet again. It's not easy loving beer the way I do. :D:chug:
Great to hear that you are back to work Pete! Recovery time means, No money, no Jeep project! Back to work: money,:)but no time :(. Vicious circle!
Same problem here, need to loose the personal spare tire so I can move better. My surgery was in October. Knee never did come back. Doctors prognosis: learn to live with the pain until full knee replacement is necessary.:censored::bang: Too many hoops to jump through to get medically approved to return to work, so I am now a member of the retired community. Hope the Jeep projects start moving a bit faster now.:D
Live with it? Jeez that's a heck of a resolution. Retirement? Now that idea I like, I just can't afford. It is a viscous circle but I'll have it back together for camping season. Staying out of the garage this weekend cause the high temperature is only in the teens. By mid week however we're supposed to be back in the 40s. :)
Damn Pete, I hope you don't plan on pulling the tub, or even change a tire .......................... :eek: There's no room!
My garage is a little strange. The area I have the Laredo in is all the way up against the back wall of my house. Any further back puts it through the wall and in my basement. Above that narrow area is the back porch in to my house. On the side is a small storage area and the door to the basement . That's why the rear is so narrow.
I knew I'd only need access to the front of the Laredo for this project so I pushed it all the way back. That leaves me plenty of room for the next Cj and the engine I'll be painting and changing all the gaskets on. It widens out a good 6ft. from where the Laredos windshield frame is. Theres a support pole on the driver side that narrows that rear area up as well. Just enough room to squeeze a Cj through. :D
And make sure you put the correct sized oil filter on too. :D
Do you know who made that valve cover?
Oh gosh darn it your going to make me use those 2 letters aren't you? The AMC 258 i6 / 4.2l I got is an '87 version. That's the stock Yj cover. Its aluminum and the head is drilled and tapped all the way around unlike some of the 80s Cj ones with the plastic cover. Good eye on the filter. I wouldn't run the right size Fram filter more a less the pummeled short fatty that's on it now. :)
The correct size(smaller OD)filter has far less chance of get'n a hole punched in it from the motor mount and flex. ;)
Seen it happen more than once on twisty/rocky trails. Just don't want it to happen to you is all.
The Fram P/N is PH 3675, WIX(AMC-OEM) is 33271.
THX for the v'cover info.
My distaste for the Frams in general was spawned from the early 90's when they had issues with the paper collapsing in the filter. I stop using them then and never looked back. I can hold a grudge. :D I usually use the Napa filters but may change that as well. I used to never get China or Mexico junk from there before but they slipped me some bad Ujoints last time I was there. I'll go with the Wix ones if the Napa ones changed. Good info on the diameter of the oil filter. I did get some new poly engine mounts since the stock rubber ones were wasted.
I'm also anti-Fram oil filters......
The NAPA Gold filters are mostly WIX.
I buy'em buy the case. Ck Amazon.
I have seen some WIX air filters with made in China labels.:mad: The last WIX AF I saw for my Jeep said China. The air filter I now use are either STP or Fram because they say 'Made in USA' on them.
A "Made in America" parts thread sounds like a good idea. Hmm.
