'83 CJ 7 Stalls
Torxhead
Always Off-Roading Jeeper
Either way will work. When AMC wired the icm ground wire to the distributor, it was a poor design as paint or grease on the distributor body where it meets the block can create a poor ground circut and ruin the icm. a loose distributor hold down can be a bad thing also. The other two wires are for the distributor pick up coil to the icm and should have a 600-800 ohm resistance between the two. when it goes bad the engine will run pretty crappy or not at all similar to a bad icm. I just snipped the wire and ran it to a grounding post that is wired to the battery negative post. On this grounding post that I have mounted to the firewall there are connections going to the head and taillights, fuel gauge sender, alternator, head, dash board, wiper motor, and starter relay. I am sure many CJ owners have similar setups since AMC has grounded much of its electrical systems to sheet metal and cast iron which provides a poor connection.
let me see if I can post it for you.
