Build Thread 83 CJ7 its time to get it done
Yes, that looks like it will work just fine. Nicely done.
And I'm glad to see I'm not the only one who gets lost in the smalls.......
I'm not telling where I sent this from.......
Well a bunch of smalls can equal a big so here we go....
That exhaust aint that bad.
I once took a large pile of old exhaust pipe and cut out what bends and straights I needed to hang a dual exhaust set up under a 65 Chevy pickup that I'd put a GTO engine in. Just fit it all up, marked how they fit and then brazed them up in the shop with the torch. My old stick welding machine was just blowing holes in the pipe and I had a bunch of brass brazing rod.
Dog ugly but it didn't leak and lasted as long as the truck did.
If you wanna feel better about your setup, I’ll send you a few pics of my exhaust mess.....
Lol I love some 7018 rod that stuff is a beast
I haven’t sat down long enough to master brazing rod yet
I just hate it that I had a well made thick wall aluminized true dual system and I hacked it up to make a single exhaust lol
So is your gas fill on the left side under the plate?
I do think I remember his gas hole being under the flip-up plate.....
I would have done the same - but a P.O. had already moved mine.....
If I had kept the CJ tank I would have also moved mine, but I wanted an in tank fuel pump when I go fuel injection and I thought the easiest way was a YJ tank
I think if it were me I would put in a fake one so it looks like a CJ from the rear since the YJ one is hidden under the plate.
My personality says this way makes people wonder where it is. Wait - nevermind. Only CJ people would notice, and they would know where it was. Everyone else would be clueless.
I know but my OCD would drive me crazy.
And fill with two nozzles at once.
Possible to spin a YJ tank 180 degrees and use the stock CJ filler location? Would require different hoses, but I wonder.....
It would be cool because you can pull up to a pump on either side. My truck has tanks on both sides and I love it because you can just pull to a pump and not worry what side it is on.
$150.00
  75.0%
